Fuel Line For E85?
Old Mar 6, 2015 | 01:13 PM
TAPyvehc93's Avatar
Default Fuel Line For E85?
What kind of fuel line do I need for E85, and where can I get some? I'm ready to install my Walbro 450 but it came with rubber hose. I always have heard that Ethanol will eat through rubber fuel lines over time.
Old Mar 6, 2015 | 05:09 PM
TimDave217's Avatar
Ive been running mine for three years on E85 with a rubber hose and i have yet to ever have a problem with it.
Old Mar 6, 2015 | 09:24 PM
TAPyvehc93's Avatar
Oh alright. I ended up doing my own research this time and I decided that I am going to go with a Gate's submersible hose from O'reillys.
Old Mar 6, 2015 | 09:38 PM
GMCtrk's Avatar
Get a nylon tube from racetronix
Old Mar 16, 2015 | 05:22 PM
hsiriyob's Avatar
do you know if the nylon tube will fit over the walbro 450 feed? racetronix shows 8mm on the id. i believe the walbro 450 is slightly larger like 10 mm iirc.
Old Mar 16, 2015 | 07:12 PM
03sierraslt's Avatar
If you heat the tube it will. I have a nylon tube on my 450.
Old Mar 16, 2015 | 09:55 PM
hsiriyob's Avatar
badass thanks man! this is a better option. did you use a worm clamp or a oetiker style?
Old Mar 16, 2015 | 10:00 PM
GMCtrk's Avatar
My recommendation is to buy a couple extra tubes - theyre cheap. The ends of the tube have to be heated to fit over the barbed output. I found the ideal temp to be when the plastic just started turning translucent. Any more then that they deform or kink. It takes quite a bit of force to get the tube on.
Old Mar 17, 2015 | 04:21 AM
This is very true.
Oetiker clamps is what I used.
Old Mar 17, 2015 | 10:07 AM
hsiriyob's Avatar
Good tip. ill try using a tapered punch to stretch the tube as i heat.
