fuel injector swap information
what injectors will fit the stock LM7 style truck intake and non flexfuel rails that use an EV1 or EV6 style connector? i can use either because i have EV6 connectors on the harness but EV1 adapter wires. the replacement injectors need to flow the same or slightly more than the stock 28lbs tech2 injectors.
when the swap back to stock is all said and done my entire GMT900 intake, fuel rail, 36lbs injectors, and 87mm TB will be in the for sale section.
