Flex fuel
Old Apr 19, 2016 | 07:39 PM
turboal1's Avatar
Default Flex fuel
The eng i installed is a Flex fuel. the truck is not. what else do i
need to change to to make it a Flex fuel truck ? It's a 2010 Colorado
Old Apr 19, 2016 | 07:47 PM
FFDP's Avatar
Likely a bigger pump to support the fuel flow of E85, then I think you'd need a E85 content sensor to wire into the computer.
Old Apr 20, 2016 | 12:15 PM
lxcoupe's Avatar
You'll need the OS enabled for flex fuel, and the sensor plumbed in and wired to pin 56 of the PCM. What are your goals and why do you need flex fuel?
Old Apr 20, 2016 | 10:30 PM
turboal1's Avatar
Default S/c
Looking to install a CTSV S/C down the line 6 to 8psi, eng has 11.4 comp
where does the sensor go ? what is the length of a Silverado flex pump ?
Old Apr 20, 2016 | 10:50 PM
lxcoupe's Avatar
Colorado bucket uses identical fuel pump motor as a Silverado, same dimensions so a Flex Fuel OEM pump will drop right in.
Teeny05
Apr 24, 2016 02:19 AM
Blwn99x
Apr 23, 2016 02:58 PM
silverstreak07
Apr 19, 2016 07:30 AM
rednekferlife101
Apr 18, 2016 09:37 PM
jsleeper81
Apr 17, 2016 11:16 AM
