Dual pump setups
Old Mar 13, 2013 | 07:55 PM
05_GMC's Avatar
Default Dual pump setups
Just wondering how many companies mke the dual in take setups and which are the best. Input appreciated
Old Mar 13, 2013 | 11:10 PM
AndysC3's Avatar
Lonnie's performance makes a nice kit. You could make your own for cheaper though
Here's some pics of mine
For the wiring, I used 10ga. 2 30a relays. I tapped into the stock pump wiring to trigger the relay. For the second pump I have a Hobbs switch in the ground for the relay. At the set pressure the switch will close and complete the circuit turning the pump on.
Old Mar 13, 2013 | 11:39 PM
silverado2000's Avatar
ANDYSC3 how full do you have to keep your tank so you don't loose fuel at WOT?
Old Mar 14, 2013 | 01:17 AM
AndysC3's Avatar
I never let my tank get to just over 1/4 tank so not sure
Old Mar 14, 2013 | 06:40 AM
05_GMC's Avatar
Thanks, my shop recommended Lonnies I was just wondering what else was out there. And thanks for the info on how to build it
Old Mar 14, 2013 | 12:07 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Is that a big crack in your bucket? Or just a bad pic?
Old Mar 14, 2013 | 01:31 PM
2toneblown's Avatar
How can nobody actually have a picture of lonnies set up?
Old Mar 15, 2013 | 09:42 PM
AndysC3's Avatar
It's a crack from where I the Bosch 044 in it
Old Mar 15, 2013 | 10:25 PM
06murder's Avatar
Pretty cool.. should get a solder iron and a zip tie and fix the crack
Old Mar 16, 2013 | 12:02 AM
Atomic's Avatar
I have a gauge for that
Heres mine with dual walbro 400s with a -8 bulkhead in an 05 bucket with an 07 top
