Drop in pump upgrade?, No Hacking!
Old May 3, 2011 | 08:40 PM
  #21
marovetsm's Avatar
Originally Posted by cfaluck13
what part number? curious what inlet location your using
I have the 11140 with center inlet. If you have a 04-06 truck you can follow the instructions on the retro radix install on Magnacharger's website. Also since I didnt have a foam sleeve to mount it in I just used an old piece of radiator hose, worked perfect.
Old May 3, 2011 | 09:30 PM
  #22
cfaluck13's Avatar
gotchya. i have an '02 but i cannot imagine the senders being too much different. Or am i completely wrong?
Old May 4, 2011 | 08:09 AM
  #23
marovetsm's Avatar
That I dont know. I think they are different just not sure how much. Hopefully someone that knows can chime in...
Even if they are I think its pretty easy to make it work regardless of the inlet.
Old Jun 2, 2011 | 06:13 PM
  #24
SVC707's Avatar
Originally Posted by Whippled 496
I copied your setup right here!!!! just did a lil different on the mount running around 8psi and only using 42lb injectors no problems what so ever. 2001 2500 hd with oem fuel pump, i have no idea how many miles on the stock pump or whats even in there since i bought the truck used. looking to change the stock pump with prolly the racetronix drop in i saw somewhere, and keep the 044 inline for extra juice
Old Aug 16, 2012 | 12:20 PM
  #25
N/ALS1's Avatar
Default Need some help.
Would like to know if the radiator hose worked fine? I to do not have the sleeve and will need to rig something up.
Old Aug 16, 2012 | 12:46 PM
  #26
03sierraslt's Avatar
In the long run I am not sure the radiator hose is going to hold up to fuel. Just a something to consider.
Old Aug 16, 2012 | 01:03 PM
  #27
N/ALS1's Avatar
That's what I wanted to know. What would be another possibility/ option?
MS3Z
Jul 30, 2015 06:17 PM
Ammadien
Jul 22, 2015 08:50 PM
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
