8100 injectors
Old Mar 14, 2013 | 06:30 PM
Team Paulie's Avatar
Registered User
Default 8100 injectors
Searched around didnt find my answer.
1.WHERE are you going to get them??? Autozone? dealer??
2. Part number?
3. Pound and flow rate?
Can I walk in the zone or where ever and say 'hey I need injectors for a 2002 2500HD with a 8100'?????
Old Mar 14, 2013 | 06:42 PM
BigDaddy0381's Avatar
Look at fuelinjectionconnect. I think that's the name. There in ga.
Old Mar 14, 2013 | 07:11 PM
SCOTT_A's Avatar
They show up for sale, used in the classified section a lot. that's where I bought mine.
they are 31 lb/hr at 58 psi
Old Mar 15, 2013 | 03:27 PM
Registered User
Usually by the time I go to jump on a set they are gone,I'm at the point that I dont care about price I just need to get a set,local is best.
Old Mar 15, 2013 | 10:29 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Ebay new take outs or low mileage run about $150-$200
Example... http://www.ebay.com/itm/8-1-L-Fuel-R...8749f7&vxp=mtr
What ever you are tuning with just find a stock file for a gas 8.1 and swap the injector tables over.
Old Mar 16, 2013 | 08:53 AM
Registered User
Heres what is going on,went and got the truck tuned a little while ago,had to use the injectors off my 4.8 cause the ones off the donor 6.0 where in no where usable shape,which at the time when I ran the parts numbers against the two it showed the same number for them,well on my new 6.0 only thing we really did as far was performance goes was a Comp cams 228R and milled the heads .20's,guess that was enough to max out the stock injectors,wanted to do the 8100 cause from what I hear is a bolt in and plug in and should have more then enough then what I need,I know it will still need to be tuned but I think wheatley can do that.
$A_Money$81
Mar 27, 2023 10:25 AM
shootermwc
Oct 8, 2015 01:45 PM
KleanKustoms
Sep 30, 2015 05:07 PM
Wrecker 426
Sep 29, 2015 11:00 PM
sTNT971
Sep 26, 2015 04:22 PM
