8100 injectors
Searched around didnt find my answer.
1.WHERE are you going to get them??? Autozone? dealer??
2. Part number?
3. Pound and flow rate?
Can I walk in the zone or where ever and say 'hey I need injectors for a 2002 2500HD with a 8100'?????
2. Part number?
Ebay new take outs or low mileage run about $150-$200
Example... http://www.ebay.com/itm/8-1-L-Fuel-R...8749f7&vxp=mtr
What ever you are tuning with just find a stock file for a gas 8.1 and swap the injector tables over.
Heres what is going on,went and got the truck tuned a little while ago,had to use the injectors off my 4.8 cause the ones off the donor 6.0 where in no where usable shape,which at the time when I ran the parts numbers against the two it showed the same number for them,well on my new 6.0 only thing we really did as far was performance goes was a Comp cams 228R and milled the heads .20's,guess that was enough to max out the stock injectors,wanted to do the 8100 cause from what I hear is a bolt in and plug in and should have more then enough then what I need,I know it will still need to be tuned but I think wheatley can do that.
shootermwc
Oct 8, 2015 01:45 PM
