450 in an 01 bucket?
From the numerous 99-03 assemblies I've taken apart, there is 1 strainer on the outside of the bucket, and 1 strainer inside the bucket which is attached directly to the pump's 2nd inlet. The pump motor is a dual inlet design. One inlet sucks from outside of the canister, the other from inside the canister which always has fuel in it once the fuel level has surpassed the top of the canister and fills it.
I realize that, that's why the 04-07 tank is a better setup as the bucket is twice as large and less likely to starve, one of the reasons I started with an 05.
I'm not sure if pulling fuel from inside the bucket will be enough with the venturi disabled. I'm going to order the pump this week and give it a shot, try and stick the sock out the bottom and run the return to the top of the bucket hopefully that will keep it kind of full or at least full enough to keep the pump cool.
Thanks guys.
Thanks guys.
lxcoupe
Jun 1, 2016 10:44 AM
Chalino Sanchez
Apr 21, 2016 12:19 AM
05GMC4.8
Apr 20, 2016 10:18 AM
