1000rwhp fuel injectors for turbo build
Old Feb 25, 2014 | 09:56 PM
Biggsw784's Avatar
Default 1000rwhp fuel injectors for turbo build
What injectors are you turbo guys using to make this kind of power with the factory ecu ??? I'll be running 93 pump gas with a meth kit. This turbo stuff is all new to me. I have always been a nitrous guru. The engine is a brand new ls2 block, Manley crank and rods and j&e pistons with a cam Crower spec'd out to this build which is 232/224 @ .050 566/566. The heads are stage 3 wcch l92s and bought a Holley hi ram ls3 intake fitted with a fast 102mm big mouth throttle body. Trick Turbo is building a badass kit for this thing too. The trans is a 4l80e with a rossler transbrake and a 3600 circle d multi disc converter. This is all going into a 01 Sierra regular cab short bed. I'll start a new thread once I start putting the truck together. Thanks for any info on the fuel side of things.
Old Feb 26, 2014 | 03:34 PM
Gadgetized's Avatar
I have 160lb Bosch injectors. I will be running E85 in the spring. There are plenty to choose from, but I would mainly make sure you have enough injector in case you decide to switch to E85. I will be doing another build this year that will also have the 160lb Bosch injectors in it.
Old Feb 26, 2014 | 10:56 PM
Biggsw784's Avatar
Thanks man. Is there any brands to stay away from or what are the better ones?? Thanks
Old Feb 27, 2014 | 08:11 AM
thewrx's Avatar
I like ID's 1000
Old Feb 27, 2014 | 11:57 AM
Gadgetized's Avatar
If you do your own tuning, I would get some that you know have accurate data. If someone is tuning for you, ask them what brand to get. They will be familiar with them and make the tuning and drivability much better.
Old Mar 1, 2014 | 10:16 AM
Biggsw784's Avatar
I have a holley hi ram ls3 intake and curious what I need to do to make the bosch 160s work in my truck. Do I need connector adaptor doe spacers for the height of the injectors?? My truck is a 01 sierra with a factory 5.3 harness. Thanks
Old Mar 1, 2014 | 10:37 AM
Biggsw784's Avatar
I wonder if I can space the fuel rail up if I have to?? I have got the intake here yet. Should be here this next week.
5.3Okasai
Mar 9, 2022 01:07 PM
USMCvet0311
Aug 14, 2015 10:28 PM
Cowboy17
Jul 9, 2015 06:18 PM
jrplz
Jul 9, 2015 12:07 AM
