07 nnbs non-flex options ???
07NNBS non flex needs more fuel . 10psi requires more that stock pump is giving. help please!
Will a flex fuel bucket and pump plug n play?
What are my other options?
Yes, a flex fuel pump drops right in, I've done it. There is another thread floating around somewhere where I did a small write up.
It will likely get you pretty far on pump gas, but I'm out of pump again around 13 psi on corn juice. I now think I'm going to T my factory pump and flex fuel pump together. Smokeshow did it a long time ago on his GMT900 with two non-flex pumps and said it supplied all the fuel he would need.
yes, a flex fuel pump drops right in, i've done it. There is another thread floating around somewhere where i did a small write up.
It will likely get you pretty far on pump gas, but i'm out of pump again around 13 psi on corn juice. I now think i'm going to t my factory pump and flex fuel pump together. Smokeshow did it a long time ago on his gmt900 with two non-flex pumps and said it supplied all the fuel he would need.
anyone using this
https://sdparts.com/details/aem/50-1200
if so how does it work with the FCPM? thinking about getting it if it works with a hotwire kit, but i doubt it will for our non flex fuel applications
anyone using this
http://https://www.performancetrucks...-pumps-519558/
Which pump are you referring to?
fixed. its a sponsor on here selling them but not sure if it will work with our FPCM. You swapped a flexfuel pump right? was it direct swap or did u have to do anything to the bucket? or any changes to FPCM?
I haven't read much about the AEM pumps. I know I've seen Walbro claims their pumps can handle the pulses, but I don't know that anyone has installed one yet on our trucks.
I did swap pumps, electronics and hoses plugged right in. All I had to do was a little trimming to the hat, as the orientation of my factory pump and the new pump was slightly different.
thompson
Dec 27, 2017 06:48 AM
Closer_2001
Sep 24, 2015 09:15 PM
