Foreign Performance Discussion Nissan, Toyota, Honda, Mitsubishi, Range Rover
My turbo mini
Old Jan 12, 2006 | 04:01 PM
turbo22rej's Avatar
Default My turbo mini
well guys this is my lil project and here are the specs below:
This was taken while I was working on it -- excuse the mess
old pic below
And a lil clip of me running a C5 with bolt-ons from a 40 mph roll (i was at 15 psi) we ended up dead even and C5 refused another run at 21 psi!
http://www.jptuning.com/videos/toyo_vs_blackvette.wmv
1992 Toyota Hi-Lux pickup 2WD short bed. A/C but no P/S from fact.
Block
Factory issued 22RE 2.4L non-turbo block - 8:5 Wiseco pistons, Eagle Rods, Stock crank.
Cyl head
match ported with +1mm stainless valves with Isky dual Valvesprings.
Intake
Stock manifold with non-turbo Supra throttle body
Exhaust
Fabbed up my own custom equal length S.S. tubular turbo manifold. 3" downpipe+exhaust 3" Hooker turbo muffler
Turbo
T-58 (aka 62-1) Turbonetics B.B., .58 Turbine P-trim wheel
Intercooler
Isuzu freight truck core with custom tanks fabbed up by me!
EFI+IGN
SDS efi distributorless crank triggered EFI. GM coil packs. Cut-n-fit Accel wires. NGK BR8ES plugs
Clutch+tranny
Stock Toyo 5-speed w/ACT pressure plate + Broward Clutch disc 6 puck solid metallic/Kevlar combo. LC engineering Billet Steel 15lb flywheel (vs.25lb stock)
Rear end
Stock Toyo 3.55:1 w/ Lock-right ratcheting locker
Suspension
Front:
Sway-a-way torsion Bars with Competition Engineering drag shocks (70 Nova SS app)
Rear:
Bell-tech 3" drop leafs + Addco Sway bar+ Competition Engineering drag shocks (67-69 Camaro app)
Dyno
338whp 331wtq @ 21 psi
ET
12.81@115mph - 17psi boost on BFG drag radial 225/50/15
Roadcourse
Don't bother - truck handling suxors!
Interior
All there with two bazooka subs 6", 400 4 channel amp, Sony headunit,
93 4-runner guage cluster w/tach + oil press ( stock clustuer only has speedo+temp guage). 93 4-runner bucket seats (stock vinyl bench seat was torture on a hot Miami day)
That should pretty much cover it all. But chime in with any questions or comments (good or bad)
Old Jan 12, 2006 | 09:00 PM
SSlow 4.8's Avatar
very nice.. thats a sleeper as long as it isnt started, bc it sounds pretty raspy. But thats something different and new. I like it.
Old Jan 12, 2006 | 09:28 PM
02sierraz71_5.3's Avatar
Nice!
damn that turbo is half the size of the engine, how long does it take to spool
Old Jan 12, 2006 | 10:12 PM
quicksilverado's Avatar
Nice sleeper. If you can manage a better short time you could see 11s.
Old Jan 13, 2006 | 11:56 AM
turbo22rej's Avatar
Thanks for the replies.
The truck idles like stock maybe even quieter due to the turbo muffling up the noise. Only when you gun it is when you hear the "air-drill" like sound from the turbo sucking.
Originally Posted by 02sierraz71_5.3
Nice!
Full boost is around 3800-4000 rpm. Ignition cut is set at 6800 rpm so it has a decent powerband to work with.
My short times are a crappy 2.1-2.2 on drag radials due to massive wheelhop. I'm looking into making something similar to Cal-trac bars b/c they don't make anything for my truck like usual. I know I have the mph to run in the 11's it's just a matter of dialing in the launch...
Sleeper - yes. Usually after a run people ask if it has a Supra motor in it but they fall off thier rocker when they see an 8-valve single cam 4-banger in there.
Old Jan 16, 2006 | 08:09 AM
Rumble Bee Ram's Avatar
I have about the same thing you do, but in a shelby dodge daytona, 2.2 TII, just finished building it for the second time in the past year.......everything forged, built 413 tranny, 3 inch exhaust, custom cal, and a ton of machine work and other mods. Its a sleeper as well, smokes most veetes. 11.2 on race fuel, anyday it'll turn 11.5s.
Old Jan 18, 2006 | 12:25 PM
the head's Avatar
Nice ride man!
I gotta go run some more times with the Scoob now that I have some exhaust bolted up to it.
Old Jan 20, 2006 | 06:19 PM
GoldenVelvet's Avatar
That is AWSOME.
Old Jan 22, 2006 | 09:55 PM
ramdaspadhye's Avatar
**** yeh man, join us at www.customtacos.com
lxcoupe
Sep 6, 2017 08:24 AM
adunphy
Feb 22, 2016 06:38 PM
chvy=power
Sep 8, 2015 11:06 AM
slowlsx
Aug 10, 2015 05:33 PM
So.cal Wrk Sled
Jul 26, 2015 12:10 AM
