Z06 cam good for Turbo?
Old Nov 15, 2007 | 07:31 PM
  #31
02RedHawk's Avatar
I've got an '01 LS6 Cam (same as LS2) if interested. Will sell it CHEAP....
Old Nov 15, 2007 | 08:36 PM
  #32
WJ MARK's Avatar
what length push rods for an 04 Z06 cam? which brand and who has the best prices on them?
Im might be buying the cam very soon!
Old Nov 15, 2007 | 08:39 PM
  #33
WJ MARK's Avatar
also with a 04 zo6 cam, where would i see the most gains? mid range and up ?
Old Nov 16, 2007 | 06:04 AM
  #34
TG02Z71's Avatar
I am wondering a couple more things as well.
What will my NA HP be after the build from 5.3l to 5.7l displacement with a Z06 cam?
I plan on about a 9-9.5-1 compression ratio, same as a stock 5.3l hopefully.
With the engine basically being a lower compression LS1 with 5.3l heads.
Can I expect say 330hp from this set up?
There will be no special head work done other than a freshening up of components where needed and possibly some better rods than stockers, as well as fasteners by ARP.
Old Nov 16, 2007 | 03:34 PM
  #35
02RedHawk's Avatar
Provided its with stock heads, proper PR length is 7.425" but you can get by just fine with 7.400" length.
LS6 cams will provide the most gains above ~3500rpm.
Old Nov 17, 2007 | 12:41 PM
  #36
ludicrist2500hd's Avatar
I have built quite a few LS FI motors currently a TB SS AWD 575awhp and 680awtq [ we have an AWD dyno in house ] Trust me when I tell you the best cam right now is LPE GT7 . 18 inch of vac at idle. Almost 0 lag . my truck idles at 550rpm and is smother then stock . Yeh it's $389 or so but it's money we'll spent . IMO . The 02-04 Z06 cam is good on the cheap works well but I have changed out a few in favor of the GT7. Get some 918's springs or manley nextec 's it will help. but you could use GM yellow's.
Old Nov 17, 2007 | 02:40 PM
  #37
WJ MARK's Avatar
I bought the 04 z06 cam. need to get the springs and maybe some hardened push rods. I plan to dyno the truck before and after the cam install. I will keep everyone updated on the outcome!!
Old Nov 17, 2007 | 03:30 PM
  #38
ZO6Ted's Avatar
You're gonna like it!
5.3Okasai
Mar 9, 2022 01:07 PM
Raggedz71
Jul 29, 2016 10:20 AM
Jake75
Jul 22, 2015 09:20 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
Atomic
Jul 11, 2015 03:51 PM
