WTF?!? I keep blowing oil pump fuses!
Old Sep 9, 2006 | 10:24 AM
vanillagorilla's Avatar
I'm not sure yet. I haven't really driven it much. I think I have a bad O2. My initial log showed that it was barely reading. Yesterday after I fixed the ground and did the plug wires it ran great. It felt like it had more bottom end than my old cam, yet it took off around 4000rpm like my old cam. Anyway, today it would barely idle and my O2 sensor wasn't reading again. Boo....
Of course, that bank could be reading lean because the injectors aren't firing properly. But then again I'd be getting some KR too and I'm not at all.
Old Sep 9, 2006 | 10:28 AM
...sounds like another battle, good luck man, i hope everything works out well for you.
Old Sep 11, 2006 | 12:59 PM
My speculating was right. It was a loose injector wire, causing bank 1 to run lean. Oh well, easy fix and it didn't cost anything. I must say though, this cam is a ton better than my old one. It has way more bottom end! I haven't boosted past 2psi as I am still tuning, but I can feel and hear the turbo spooling faster. Plus a smooth idle at 700rpm is a lot better than a rough one at 900-950 rpm and only 9" Hg of vacuum.
Old Sep 11, 2006 | 05:43 PM
kbracing96's Avatar
Its a nice, CHEAP cam
Old Sep 11, 2006 | 05:46 PM
thunder550's Avatar
High on diesel fumes
Originally Posted by kbracing96
I told ya!
There's 2 different length plug wires, ask Chris how he knows this
Shhhhhh!!!!!
Old Sep 14, 2006 | 08:56 AM
onyx's Avatar
14 Second Truck Club
good to hear it got running Todd. i'll be home sept 20th. we need to check some of my **** out.
Old Sep 14, 2006 | 10:11 AM
Now if I can only get the 3 bar MAP to work.
Old Sep 14, 2006 | 11:33 AM
BlownChevy's Avatar
blownerator
25 Year Member
I miss you
5.3Okasai
Mar 9, 2022 01:07 PM
chopperloco
Jul 10, 2016 10:45 PM
JordanH
Aug 8, 2015 07:59 PM
Ammadien
Jul 22, 2015 08:50 PM
Ferocity02
Jul 17, 2015 07:05 PM
