Wrap vs Ceramic coating
Old Oct 23, 2011 | 10:47 AM
scooter k's Avatar
Default Wrap vs Ceramic coating
Will the Ceramic Coating help keep the underhood temps down just as much as the wrap?
Old Oct 23, 2011 | 02:33 PM
FarmTruc's Avatar
Performance Trucks Sponsor
No, wrapping is better.
Compare it next time you get a chance, radiant heat is lower with wrapping.
I've tried all the coatings, always went back to wrapping when underhood temps are a concern.
Not that coating doesn't work, it does great.
Old Oct 23, 2011 | 02:58 PM
scooter k's Avatar
Is it worth doing both?
Old Oct 23, 2011 | 03:02 PM
02'Z71ONDUBZ''s Avatar
Ive got both on mine, I dont think it would really be worth it unless your hot pipes were made of mild steel. It would probably help with corrosion from the wrap in that case.
Old Oct 23, 2011 | 03:16 PM
scooter k's Avatar
I have stainless hot pipes except the log manifold
Old Oct 23, 2011 | 03:21 PM
chevyboy.520's Avatar
Id just wrap them with some good wrap, no cheap wrap. I had some cheap wrap come apart within a week. I sealed my DP and turbo manifold with some good wrap, and have had no problems, now on the other hand. My crossover, was wrapped with a cheap brand of wrap, and it came apart.
Old Oct 23, 2011 | 03:48 PM
Alpinestar's Avatar
If you decide to go with the wrap just use regular hose clamps to hold the wrap in place. They work a lot better than DEI's wrap ties but just doesn't look as professional. If you do end up going with the DEI ties, I could sell you mine that I didn't use on my hotpipes.
Old Oct 23, 2011 | 04:04 PM
sureshot's Avatar
Would just having the pipes ceramic coated be enough? Or would wrap still need to be used?
Old Oct 24, 2011 | 10:29 AM
M&M Turbochargers's Avatar
i like to use safety wire to hold my wrap on
Old Oct 25, 2011 | 10:06 AM
Secs-10's Avatar
^^ me to. If you've ever done any MX racing and wired your grips on just do the same on the wrap. Works great and ALOT cheaper than the stainless ties
SS94S10
Jan 3, 2019 01:57 PM
turbo6c3
Oct 5, 2015 06:11 PM
Wolftrk99
Oct 2, 2015 08:17 AM
97_ek
Sep 23, 2015 09:16 PM
