wiring up a innovate lc1
Old Aug 28, 2009 | 08:33 PM
Daryn's Avatar
Formerly darynC-10/23/10
Default wiring up a innovate lc1
okay i have a 07 silverado. where to i wire up the switched powersources to the gauge and cable?
Old Aug 29, 2009 | 10:43 PM
95TwinTT's Avatar
Registered User
Are you replacing one of the O2's or just using it for a AFR gauge?
Old Aug 29, 2009 | 10:45 PM
RandomHero's Avatar
Your best bet it to get a test light from Sears or Harbor freight or whatever. I found my keyed source under the dash off the drivers side fuse panel.
Old Aug 30, 2009 | 12:55 AM
Daryn's Avatar
i welded an extra bung behind the drivers o2 sensor
Old Aug 30, 2009 | 02:06 AM
95TwinTT's Avatar
Registered User
What kind of guage are you using? Wide band? Digital?
Old Aug 30, 2009 | 10:05 AM
Rick_Vor's Avatar
Ditto when I added my LC1. I added a pigtail to the switched fuse and used it for me LC1 + gauge power and for my Aeroforce Interceptor scan gauge.
Rick
Old Aug 30, 2009 | 09:08 PM
Daryn's Avatar
im using a digital gauge that came with the kit the instructions said the guage has to be on a ignition witched power source and the o2 sensor has to be on a switched power source?
Old Aug 30, 2009 | 10:05 PM
95TwinTT's Avatar
Registered User
Here is a link to the littlefuse "add a fuse". It makes life easy. You can hook up the LC-1 and the XD-16 to the same fuse. The LC-1 needs 5 amps and the digital gauge needs 2 amps. A 7.5 amp fuse would do nicely.
http://www.littelfuse.com/data/en/Da...FHM02FHA02.pdf
The red wire from both units should go to the fused power switched from the ignition. You can piggyback any of the fuses in the panel that are switched.
They like to keep the heater ground (blue), grounded separate from the system or signal ground (white) to keep the electronic noise to a minimum.
00loudchevy
Dec 3, 2015 05:54 PM
bearden86
26
Nov 15, 2015 03:58 PM
JordanH
Oct 3, 2015 03:59 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Wrecker 426
Sep 30, 2015 09:39 PM
