will these turbos be enough ?
Old Jun 12, 2015 | 08:06 PM
Alco's Avatar
Default will these turbos be enough ?
Hi everyone, I've got a deal for a pair of IHI VF39 turbo ( of a Subaru STI) From what i've found on google they are rated at 425 cfm/17 psi ( so 850 cfm for both) and seen these turbo pushing 380 lbs of torque on a daily driven 2.5L !
I'm targeting 500/525 hp with minimal lag. Would these turbo be a good match for my 2002 gmc sierra 5.3L???
Old Jun 12, 2015 | 09:54 PM
JordanH's Avatar
Restricted
Don't these turbos have some weird turbine housing mount? I don't think they would be a good match.... Plus I'm pretty sure nobody makes a Hotside that would be a direct fit/bolt-up for the vf39 turbo mounting assembly... I say sell them, and buy a good Precision Or Borg Warner turbo!
Old Jun 12, 2015 | 10:10 PM
Alco's Avatar
thanks for the help!! my question is mostly about the turbo vs the engine size ! I have access to flanges and the fab work isn't a probleme !
here are some picture of what the parts look like
Old Jun 13, 2015 | 12:01 AM
JordanH's Avatar
Restricted
I'm gonna see if I can find some specs on those turbos, but just from looking at the pics, it seems like the turbine/AR is going to be way to small for the 5.3 motor.... Even on a twin setup
Old Jun 13, 2015 | 11:29 AM
Alco's Avatar
thanks !!
Old Jun 13, 2015 | 01:51 PM
George C....'s Avatar
Formerly ScreamingL
Too small
Old Jun 13, 2015 | 02:52 PM
08DenaliT's Avatar
Yea I'd think you'd be making boost as soon as you started moving.
Old Jun 13, 2015 | 03:06 PM
JordanH's Avatar
Restricted
That's what I was thinking! Maybe maxing them out around 4,500 rpm?
Old Jun 13, 2015 | 04:15 PM
Funkster's Avatar
12 Second Club
I am a former Subaru owner (Forester XT w/VF39, E85, etc.)
The turbo will be too small for your application. You will have back pressure issues and your powerband will be up way too early to be practical. The VF39 is honestly too small for a 2.5L engine in most situations.
Old Jun 13, 2015 | 09:15 PM
Alco's Avatar
Thanks for the info! What would be a commenly and low cost turbo (oem or aftermaket ) to do a twin setup?
