Will L92 heads help THAT much with FI?
Old Feb 14, 2007 | 08:58 PM
staffcurtis's Avatar
Default Will L92 heads help THAT much with FI?
I'm building a forged motor to probably be used with an STS turbo kit. I have my choice of heads right now, and the L92 heads/intake combo seem an awesome combo...but most of the tests I've seen are with NA engines. Would FI actually benefit as much, or is there a better option? The L92 combo price is also hard to beat.
Thanks
PS...Not sure my bore at this time but it's probably between 370 and 408 when complete (on 2003 AWD escalade)
Old Feb 14, 2007 | 09:14 PM
I have read over on tech if you get pretty high PSI, as with any factory cast, they will lift
Old Feb 14, 2007 | 09:31 PM
I'm looking for 600rwhp, and 12psi max. I was hoping for the same PSI, these would give me more power.
Old Feb 14, 2007 | 09:38 PM
nightrunner's Avatar
Mr. Obvious
fyi 370 and 408 have same bore but 408 has 4" stroke crank
Old Feb 14, 2007 | 09:42 PM
If the L92's aren't the best option for FI, then what's better for the same $$$?
Old Feb 14, 2007 | 09:54 PM
8ALTNG's Avatar
AFR's are proven to work wonders with FI. ETP arnt to shabby either.
What size turbo are you going to run????
Old Feb 14, 2007 | 10:14 PM
Not sure at this point. I had planned to start another thread to ask that information. I'm all ears if you have any ideas.
Old Feb 14, 2007 | 10:16 PM
8ALTNG's Avatar
You need to run at a minimum of a 76mm with a .96 housing to make power with that 408.
Old Feb 14, 2007 | 10:20 PM
TurboGibbs's Avatar
Yeah, but many have proven that if you run arp studs tq'ed to 80-85lbs with factory MLS gasket they will hold pretty well. Slowhawk swears up to 1000 hp with factory castings. But I dunno for sure. If you stay in the 10 psi range factory heads should be just fine.
Old Feb 14, 2007 | 10:31 PM
kbracing96's Avatar
If I remember right, Parish went close to 900rwhp on boost and 1000 with a little spray on his stock 317's before he finely broke down and bought a set of AFRs
OHsixLS3
Dec 27, 2016 09:30 AM
USMCvet0311
Sep 30, 2015 10:34 AM
subeone
Aug 19, 2015 07:44 AM
USMCvet0311
Jul 29, 2015 01:28 PM
NuckenFuts
Jul 9, 2015 08:45 AM
