Will I gain anything from this?
Old Sep 27, 2011 | 11:58 PM
  #21
slowfive0's Avatar
No problem!
Originally Posted by AKlowriderZ71
Cool, thanks for the info. I won't be changing my setup anytime soon, it seems to be working just fine. But I've always got my hands in a project of some kind, and I really like to know what's out there.
Old Sep 28, 2011 | 10:30 AM
  #22
SC6PT0's Avatar
On LPE's site they do have a 100MM MAF that is 4".
Lingenfelter 100 MM Mass Air Flow Sensor - MAF - GM Applications - Lingenfelter Performance
1999-2006 Silverado, Sierra, Tahoe , Yukon , Escalade, H2
Wonder how this would work...
Old Sep 28, 2011 | 10:52 AM
  #23
Gadgetized's Avatar
Did you find some thin-wall aluminum tubing? All the stuff I found was really thick, and really reduced the inside diameter more than I wanted to accept.
Hook a brotha up & grab a tape measure & camera!
I bought a 120 degree 4" piece off of EBay, and it almost seemed too thin. I had a piece of 4" aluminum straight left over from my car. I will more than likely have it all welded together tomorrow. The filter should be showing up today after work. Hopefully I can get it back up and running quickly. I should have pics tomorrow.
Old Sep 28, 2011 | 11:16 AM
  #24
03tahoe22's Avatar
I got a 100mm LPE for sale (used for 500miles).... just have to buy the correct harness for it.
Old Sep 28, 2011 | 03:02 PM
  #25
Gadgetized's Avatar
Here is a quick pic I just took. I still have a lot of trimming to do on the box around the filter obviously. One side is still cardboard, but you get the idea. I have a ram air hood, and there is an opening for it directly above the filter when the hood is closed.
Old Sep 28, 2011 | 07:15 PM
  #26
supersub's Avatar
my .02
Every little bit helps!
Old Sep 28, 2011 | 07:17 PM
  #27
supersub's Avatar
adding this to the above ported 90mm inlet alows the 102mm to bolt up
Old Sep 28, 2011 | 07:19 PM
  #28
supersub's Avatar
Now we need to find some one to put a 102mm on a 112? I am running the 102mm on both of my 2300's
Old Sep 28, 2011 | 08:37 PM
  #29
Gadgetized's Avatar
If I can't get my DBW to work I will be converting my Radix to a 102mm DBC.
Old Sep 28, 2011 | 11:41 PM
  #30
AKlowriderZ71's Avatar
11 Second Hall Moniter
I think the j-tube might be the bottle-neck if you try to go 102mm on a MP112.
