Who has ran Both- PD blower and a turbo? Not together
#81
The gas engine catalysts I work with are rated to a steady state working temperature of 950C, and the exhaust gas itself is almost always higher...so if that tells you anything...
#82
I messed around with cruise AFR and timing to try and get it down and never made much progress going through a big range of values. Sensor package really wasnt good enough to do WOT testing with that. 18 or so degrees of timing at 11-11.5 AFR.
#89
Yea youre gonna be bored so fast with that turbo
But than again no turbo that makes the top end you want will spool as fast as you want. Pretty sure I sound like a broken record by now
