Whitish smoke on deceleration.
I was logging the truck and notice that when i make the turbo spool and let go the gas whitish smoke comes out
Even when i go WOT and let go the gas it does it. It do not happen all the time every 3 to 5 times when i spool it or i go WOT.
Here's a video.
Truck specs are, 60,boost cam, trick 76mm kit on 3 psi.
smoke - YouTube
Even when i go WOT and let go the gas it does it. It do not happen all the time every 3 to 5 times when i spool it or i go WOT. Truck specs are, 60,boost cam, trick 76mm kit on 3 psi.
smoke - YouTube
Yes i kinda see it bluish, What causes that?
Noting its wrong with the motor we just start it up and and i start logging it air fuel at cruise is at 14.5 at WOT with 3 lb's its at 11.3
I was thinking i need a catch can
I'm going to have to agree with Tim. Is it possible you have a crankcase vent tube running into the intake plumbing somewhere between the turbo outlet and the throttle body? If you've got that scenario then the crankcase will build boost pressure and then come surging back out when you lift the throttle, and that will carry with it plenty of oil. Crankcase pressure is BAD so definitely check this out.
