Whipple throttlebody elbow help
Old Nov 2, 2007 | 03:08 PM
Bromaguire's Avatar
Default Whipple throttlebody elbow help
I need to change the throttlebody elbow on my whipple kit I am installing. The kit is a dual belt setup from a 2000 5.3 tahoe that will be installed on my 03 Yukon Denali. I called whipple today and they said that they no longer sell the elbow I need. What have others done to get around this problem? Whipple suggested having a custom one made. What type of shop could make this? Does anyone have an idea of what it might cost to have a custom one made?
Also is whipple the only place to buy new pulleys from?
Old Nov 2, 2007 | 07:08 PM
MikeGyver's Avatar
Do you mean the elbow that is on the front of the manifold, that the blower blows into? Or do you mean the end housing of the compressor that the throttle bolts onto? If it is the first one, I have one, PM me.
Old Nov 2, 2007 | 07:27 PM
Bromaguire's Avatar
I am looking for the end housing of the compressor. The problem I was told is that whats on the compressor now sticks out to far and will hit the firewall.
Old Nov 2, 2007 | 10:12 PM
BigTex's Avatar
I ran the same style kit on my 03 Tahoe. I did two things to make it fit: I elongated the bolt holes on the TB to allow me to 'clock' the large side down away from the firewall, and I used the big F'n hammer to clearance the firewall enough that the TB plug didn't make contact. Other than that, everything fit like a charm. My Tahoe is flex fuel, so I was able to use its larger stock injectors and not hook up the whipple computer and extra injectors.
Old Nov 2, 2007 | 10:41 PM
Bromaguire's Avatar
The compressor thats coming with my kit has a different elbow than the one in your picture. This is the compressor unit I bought below. Will I be able to just follow the same process you did to make it work?
Old Nov 2, 2007 | 11:03 PM
BigTex's Avatar
Yours already has the elbow on it. See how my TB points 90* away from the compressor? Yours has the elbow that rotates the TB forward and points it along side the compressor. You shouldn't need any major modifications.
Old Nov 2, 2007 | 11:20 PM
Bromaguire's Avatar
Nice, thats what I was starting to think after looking at where your throttle body bolts up as to where mine will. So this eliminates the problem with clearing the firewall now, right?
Old Nov 3, 2007 | 12:05 AM
BigTex's Avatar
That is correct.
Lthompson
Oct 2, 2015 12:45 AM
TrickTurbo
Sep 25, 2015 11:22 AM
lsxperformance
Sep 20, 2015 11:08 AM
whippledstepside
Sep 17, 2015 05:02 AM
scooter k
Sep 16, 2015 10:32 PM
