Whipple Owners
Old 06-21-2012, 07:26 AM
A-Dub's Avatar
Default Whipple Owners
I'm looking at picking up and old non intercooled side mount whipple to use on a future 5.3/6.0 swap into an older truck. I don't know a whole lot about them other than I will delete their electronics and run my own injectors and tune.
Being that they aren't intercooled, whats their power and boost potential? The truck will be a cruiser and the blower will be used to boost torque. No track or road racing, won't be a DD. I don't think I would add meth or an IC.
AW
Old 06-22-2012, 07:18 AM
A-Dub's Avatar
Lot of views, no replies?
Old 06-22-2012, 07:28 AM
I have a gauge for that
Atomic's Avatar
I helped a friend put one on his 2500hd...they get pretty hot, but as long as you keep it below 8-10psi you should be fine.
Old 06-22-2012, 07:44 AM
A-Dub's Avatar
Do you remember what kind of power he made?
Old 06-22-2012, 08:32 AM
CCrowell2's Avatar
My old 2003 chevy 2500hd 4x4 with the 6.0 and a side mount whipple made408hp and 465ish tq on the dyno. no intercooler only other mod on the truck was magnaflow exhaust.
Old 06-22-2012, 08:56 AM
CCrowell2's Avatar
on 7-8 psi
Old 06-22-2012, 09:56 AM
A-Dub's Avatar
Thanks. I assume you towed a lot with your HD? No detonation issues?
Old 06-22-2012, 03:53 PM
Bama2door's Avatar
I'm Atomics friend with the Kenne bell side mount, running about 6-7 lbs on 35" tires, non intercooled with just electric fans and a drop in magnaflow. I'd say it's probably 380-410 how it sits. I need to get it on the dyno when I get back home in August.
I'd like to somehow figure out a way to run an IC, and I also want to swap cams and do full exhaust etc
Old 06-22-2012, 08:04 PM
Applegarth's Avatar
I had no issues racing in the south Georgia summer heat. Never raised the boost. I don't believe Whipple provides any support for these blowers anymore (smaller pulleys, etc) so you may have troubles getting more boost if so desired.
Old 06-23-2012, 11:10 AM
Gordy M's Avatar
The Kenne Bell and Whipple used basically the same rotor for their sidemounts, The main difference were the KB came with 8.1 Marine injectors and Whipple had the electronics. Also, the KB had a fairly good cold air intake which allowed better HP at low boost (5-6 psi). When tuned properly they made good HP and several owners have altered the sidemount to run through an intercooler-worth 20-30 more HP. IAT mounted just before the intake will really tell you how effiecient it is running, the cooler they run, the more dense the change and more HP. Both are excellent for towing and headers really wake them up.
Quick Reply: Whipple Owners
