Whipple mil flashing. Please help.
Old Jul 8, 2018 | 02:14 PM
BlownH2's Avatar
Default Whipple mil flashing. Please help.
Hey guys i have a 2003 H2 with an older whipple 2300axo sidemount supercharger. Early today i noticed that the "whipple check engine" light was flashing at me. Nothing seemed out of the ordinary everything runs fine and the trucks dedicated cel is not on. But the flashing never stopped. It would flash twice, take a pause and then flash one time. Like morse code. And then during acceleration, the light would just stay illuminated until it i reached cruising speed. Unfortunately when i purchased the truck, the whipple paperwork never came with it, so im at a loss to try to figure out what code is being generated. Does anybody here have an owners manual that could help me out?
Old Jul 8, 2018 | 05:00 PM
madmann26's Avatar
Best thing you can do is dump the Whipple tronics and get some larger fuel injectors/fuel pump and a good tune with EFI or HPT.
That's what most people will tell you.
Old Jul 8, 2018 | 05:27 PM
BlownH2's Avatar
thats what the plans are, but right now its not exactly feasible.
Old Jul 8, 2018 | 10:37 PM
MikeGyver's Avatar
You have had this truck for awhile and still haven't spent the money to fix it. I think that I understand your line of thought, that there must be something reasonably simple wrong and relatively easy to fix once you decipher the codes. After all, Whipple is a reputable company and this truck must have ran great when the kit was first installed, right? No, the best mine ever ran with the Whippletronics was the same as stock except with more low rpm torque. Would have been ok for towing, but it never fulfilled the dream of supercharged power. It flashed codes and opened the bypass from day one. It doesn't matter what the Whipple computer is dreaming about when it flashes its lights, you are not going to fix it.
You need to bite the bullet and fix it correctly if you want performance and to get rid of those phony codes. There is nothing that can be done to make it right if you keep the Whippletronics. Honest. So if it costs $1000 for a tune, injectors, and a pump (I don't know how much, I figured that was a high estimate), then that's what it costs.
It's none of my business about your monetary situation, but if something else happened to your truck to keep it from running, and it cost the same as a tune, injectors, and a pump, would you have to park it? My point is that your truck is broke, fix it right or live with it.
Sorry.
Old Jul 8, 2018 | 10:44 PM
MikeGyver's Avatar
The reason that Whippletronics ever existed was because these kits were made before aftermarket tuning was available. The kits were mechanically ok, they just had to use their piggyback system to do the best that they could without being able to break into the stock PCM.
Old Aug 27, 2018 | 04:22 PM
Flying Skunks's Avatar
Registered User
If ones black box has been modified by BlackBear , are you suggesting eliminating the Whipple computer ? Mine just started flashing today
___ _
Old Aug 27, 2018 | 04:24 PM
Registered User
I have the side mounted Whipple on a BBC in a 98 C3500
Old Aug 30, 2018 | 08:08 PM
MikeGyver's Avatar
I believe that your truck is supported by HP Tuners. If so, I think everything I said before applies. New injectors, pump, and tune. Ditch the Whippletronics.
Old Aug 31, 2018 | 04:56 AM
Registered User
Soumds like a good weekend project ..it is supported by HP tuners , and already have larger injectors , pump , and tune installed ..
Thanks
Old Aug 31, 2018 | 06:24 AM
MikeGyver's Avatar
Why do you still have the Whipple computer? Are you still using the Whipple auxiliary injectors if your kit came with them?
