whipple install help ??
Old Aug 30, 2012 | 09:07 PM
ou812sm's Avatar
Default whipple install help ??
Well I still haven't installed it yet but I'm gonna try it I know I've ask in past how hard its to do but the instructions seem to be well laid out so I'm gonna do it this Saturday any pointers you guys can give anyone locally that has done this that would like to give me a hand I'm in southern mass I would appreciate it
Old Aug 30, 2012 | 09:39 PM
dick_landy's Avatar
Cleanliness. Use zip lock bags for your parts and label them.
Old Aug 31, 2012 | 12:42 AM
PRO TOUR HOE's Avatar
which one are you installing and whay are you installing it on ?
Old Aug 31, 2012 | 01:52 AM
ou812sm's Avatar
I'm in installing a 2300 whipple on a 2009 sierra denali
Old Aug 31, 2012 | 06:52 AM
Boober's Avatar
Just take your time. Follow the instructions, they are pretty good. The only area that is lacking is mounting the heat exchanger. You will need to do some cutting to get it to fit properly but it WILL fit. The only other suggestion is to DEFINITELY have someone there to assist you when you go to put the supercharger in place on the engine. It is a heavy sucker! Also, the manual describes getting a tool to move the AC lines at the firewall. I did not need to do this, there was plenty of room, since our trucks are probably nearly identical, just ignore this step.
Old Aug 31, 2012 | 08:21 AM
ou812sm's Avatar
Can explain what you did to get it to fit
Old Aug 31, 2012 | 09:18 AM
If you have problems with the heat exchanger mounting I have Art Whipples 09 GMC at my shop doing some paint work right now I can get a couple of pics if you need them its got the 2.3 on it
Old Aug 31, 2012 | 09:26 AM
ou812sm's Avatar
That would be awesome can you send it to my cell 7745219551
Old Aug 31, 2012 | 09:44 AM
Boober's Avatar
I have a few pics I can try to post up...
Old Aug 31, 2012 | 09:53 AM
Boober's Avatar
Here is the support before I cut into it. The yellow markings are where I cut.
Here is the support after I cut both sides.
This is a really dark picture but this is the HE mounted to the support with the supplied brackets. You might need to adjust the brightness on your monitor or if you have a photo editing program, you can brighten it.
