Whipple help please
Thanks. So when I remove all the whipple stuff I won't need anything for ss once removed?? So what u are saying about my 4.8 is I can remove all the whipple wiring crap an just new injectors an a tune. What do I do about where the extra whipple injectors are. Is there like a new elbo that replaces it without the injectors Where the throttle body goes. I'm starting to remove it in the am any help ASAP thanks a lot for your time
8 Second Club
You will need the elbow extension that puts the TB facing forward This is needed to make room for the TB electronic motor.
Or you can beat the firewall in some. (Assuming whipple is going on the etc vehicle)
Injectors will depend on how much power u plan on making.
42 pound marine should be direct drop in.
Look where is the cheapest place to buy these injectors? Also hers was dbw minE has a cable an the cable isn't long enough since the spot where throttle body mounts on the ss the whipple comes with a diff elbo part. I don't have this piece can I get longer throttle cable.? What cable could I get. Anyone done this. Thanks for helping I got it mounted just need exstention on the iac an tps
whippledstepside
Sep 17, 2015 05:02 AM
scooter k
Sep 16, 2015 10:32 PM
