Whipple help please
Old Mar 9, 2013 | 10:44 PM
99whipple's Avatar
Registered User
Swap everything from the 6.0 to the 4.8.
Get some good injectors and a tune.. that takes care of the crappy electronics.
Thanks. So when I remove all the whipple stuff I won't need anything for ss once removed?? So what u are saying about my 4.8 is I can remove all the whipple wiring crap an just new injectors an a tune. What do I do about where the extra whipple injectors are. Is there like a new elbo that replaces it without the injectors Where the throttle body goes. I'm starting to remove it in the am any help ASAP thanks a lot for your time
Old Mar 9, 2013 | 11:13 PM
SCREAMINXL's Avatar
Please post up under hood pictures of the whipple setup.
Old Mar 9, 2013 | 11:49 PM
8 Second Club
You keep the whipple extra injectors but don't plumb them or wire them. The stay on just for looks. (Or you can make a block off plate)
Old Mar 10, 2013 | 05:54 PM
99whipple's Avatar
Registered User
Ok thanks So I will not need any parts to swap the whipple from one truck to anther ?
Old Mar 21, 2013 | 10:31 PM
99whipple's Avatar
Registered User
One more question what size injectors an where to buy?? Also since her truck is drive by wire will I need any other parts since mine has a throttle cable ?? Sorry that's two questions lol
Old Mar 22, 2013 | 12:13 PM
8 Second Club
You will need the elbow extension that puts the TB facing forward This is needed to make room for the TB electronic motor.
Or you can beat the firewall in some. (Assuming whipple is going on the etc vehicle)
Injectors will depend on how much power u plan on making.
42 pound marine should be direct drop in.
Old Mar 22, 2013 | 09:22 PM
99whipple's Avatar
Registered User
Look where is the cheapest place to buy these injectors? Also hers was dbw minE has a cable an the cable isn't long enough since the spot where throttle body mounts on the ss the whipple comes with a diff elbo part. I don't have this piece can I get longer throttle cable.? What cable could I get. Anyone done this. Thanks for helping I got it mounted just need exstention on the iac an tps
Lthompson
Oct 2, 2015 12:45 AM
lxcoupe
Sep 22, 2015 02:50 PM
whippledstepside
Sep 17, 2015 05:02 AM
scooter k
Sep 16, 2015 10:32 PM
MS3Z
Jul 30, 2015 06:17 PM
