Whipple bypass valve - can it wear out?
I have an older Whipple kit from "back in the day" on my 2000 Silverado. It has been on the truck for about 80k miles and I have done other mods over the years. One thing I did was put a smaller pulley on it to raise the boost to 8-9 psi. Over time the boost started to decrease - I am thinking that it was due to the valve springs in the stock heads wearing out and bleeding boost. It was down to around 6-7 psi.
Anyway, I put some PRC 2.5 heads on the truck and a Comp 224/228 114 lsa cam in it and it really woke up the old motor. Now I see 8-9 psi on the gauge until 4500 rpm where it starts to fall off steadily down to around 6 psi by redline, which is set at 6400. The guy at Whipple says it should stay up around 8-9 psi to redline and I may have a vacuum leak.
So over the weekend I replaced all of the vacuum lines and tightened the belt to make sure it wasn't slipping. I even disconnected the vacuum lines from the bypass valve and clamped it closed. Same result.
So my question after all this is - has anyone ever had to replace the bypass valve on a Whipple? Mine is an older AXO compressor and is considered by today's standards to be small. Also, is the only place to get a replacement from Whipple?
Thanks!
Thanks!
I removed the vacuum from the valve and did the zip-tie method yesterday and it had no effect. All of the Whipple-tronics and extra injectors were removed years ago. It is now only vacuum controlled.
