where the hell is my oil
Old Mar 26, 2010 | 10:20 PM
  #31
scotthughes's Avatar
Banned Scammer
yeah...at this point...if i lost another 6.0....id be more pissed then i could stand. well know tomorrow evening.
Old Mar 26, 2010 | 10:42 PM
  #32
thunder550's Avatar
High on diesel fumes
Sounds like the engine ingested enough oil to bend the rods. I'd check and double check and triple check your PCV system and the turbo compressor side seals. You shouldn't be able to wipe wet oil from the throttle body. Find and fix the problem now before it destroys another engine. If you stick another engine in there without doing anything I'd put money on that one dying in short order as well.
Old Mar 26, 2010 | 10:48 PM
  #33
Banned Scammer
thats kinda what im thinking. i would kill to know what caused it. its nothing apperent thats for sure. im kinda hesitant about just sticking this motor in and hoping for the best...but the turbo is obviously done corectly. what exactly should i check before driving it?
Old Mar 26, 2010 | 10:52 PM
  #34
thunder550's Avatar
Do you have a PCV system? How is it set up?
Old Mar 26, 2010 | 10:55 PM
  #35
AKlowriderZ71's Avatar
11 Second Hall Moniter
Who is doing the work for you?? You keep saying nobody can find anything wrong with anything. But you have oil in the throttle body...... Ding ding ding, that IS a problem.
Old Mar 26, 2010 | 10:56 PM
  #36
Banned Scammer
its kb's kit
Old Mar 26, 2010 | 10:58 PM
  #37
I didn't ask who's kit. Who is working on your truck.
Old Mar 26, 2010 | 11:03 PM
  #38
Banned Scammer
EARTH MOTORS hes did a damn fine job. I think it was just a weak motor. Im pretty sure it just had more miles then i thought
Old Mar 26, 2010 | 11:10 PM
  #39
A mis-routed pcv system isn't going to go thru 3 quarts of oil in 10 miles. Especially if you say you babied it and stayed out of boost. At this point, by your description of events, the turbo is suspect. If you have oil in the intake, there's a telltale sign. You also say you have bent rods. If enough oil(3 qts in 10 miles is alot) was being pumped into the combustion chambers, this could also happen. What has me confused here, is that your mechanic, who did a damn fine job, can't figure this out. Good luck with your truck, I really hope you get it fixed quickly and correctly, without any more problems.
Old Mar 26, 2010 | 11:25 PM
  #40
Banned Scammer
well thanks for all the help. well see.
