what's the limit on stock bottom 5.3 ??
Old Jan 11, 2011 | 09:29 PM
08cheyennesc's Avatar
Default what's the limit on stock bottom 5.3 ??
Is anyone running 12 psi or more on a stock 5.3? I want to push my 5.3 to its limit,currently 10 psi ,will be doing cam,pushrods,DOD delete,timing set,LTs ,ORY,3 core intercooler (2 core now) but don't want to mess with bottom end and heads. Can it take 12 psi or more?
Old Jan 12, 2011 | 12:47 AM
02'Z71ONDUBZ''s Avatar
Yes, it can handle 12lbs but you pushing it if you want it to last. It's all in the tuning at that point, also you will definitely need to spray meth. I think you will run in to belt slip before you reach the 5.3's limits, assuming you have a 6 rib setup.
Old Jan 12, 2011 | 12:57 AM
Or should I wait and save to build it to a 370 and a F1 blower? I do have a 6 rib now with regular pulleys and has some belt slip already.
Old Jan 22, 2011 | 10:05 AM
JimS's Avatar
My gauge says I'm building 14 or 15 pds. I'm planning on adding a 150 shot of nitrous.
Old Jan 22, 2011 | 11:07 AM
smokeshow's Avatar
Mod with training wheels
I think if you want to get serious with blown power, you need to go beyond the 6-rib. But like you said, at that point it makes sense to just drop a bigger engine in.
Old Jan 22, 2011 | 12:04 PM
lady3bglover's Avatar
Are you still running on stock 4L60E, G80, and 3.73's?
Old Jan 22, 2011 | 02:45 PM
I still got the stock tranny, will be getting a built one soon, I have 4.10s now
Old Jan 22, 2011 | 06:12 PM
ForcedTQ's Avatar
Lightbulb
Your could get a set of Forged Wiseco stock bore pistons, and a set of ARP rod bolts. That would be a nice little insurance package. If you want find a set of decent K1 or Callies rods.
I know you said "stock", but I thought I'd add a little info in case you were referring to "stock displacement."
Old Jan 22, 2011 | 06:20 PM
LS1DIME's Avatar
Well I know my tune was off a bit, but mine didnt last but a short bit @ 18psi! But I would suggest have yourself a nice replacement waiting or like forcedtq said throw some parts at the 5.3l!
Old Jan 22, 2011 | 06:31 PM
I've been taught to build from the back up.. make sure you have supporting components for your additional Hp.
Lisa
