What's everyone's take on this for 4" exhaust?
Old Jun 6, 2019 | 10:00 PM
  #31
Resolute_welding's Avatar
Definitely not a straight swap affair but it's in.
Old Jun 7, 2019 | 05:47 PM
  #32
Merctech2's Avatar
Did you use the muffler that came in the kit?
Old Jun 7, 2019 | 05:48 PM
  #33
Yes sir. I'll swap it to another true 4" muffler down the road.
Old Jun 8, 2019 | 09:14 PM
  #34
randeez's Avatar
little late to the party, but this is pretty much the same i did with mine. I grabbed the cheapest 4" straight pipe exhaust for a 2010+ duramax truck was like $250 iirc in stainless, magnaflow 4" straight thru mufflers a 30" and a 6", added a flex section.
wasnt a direct fit by any means but the over the axle section was pretty close, had to move all the hangers, i added in some vbands where it makes putting it all on and off easier.
Old Jun 11, 2019 | 09:55 AM
  #35
BlackPanther6.0's Avatar
mine doesn't look like it sticks out too much, i since have added my rear seat back and it did quiet down inside.
Old Jun 11, 2019 | 05:58 PM
  #36
Merctech2's Avatar
Finally got my kit on. Went together pretty easily, didn’t even have to cut anything. My tip don’t stick out neither.
Old Jun 11, 2019 | 06:20 PM
  #37
Mileguru's Avatar
[QUOTE=BlackPanther6.0;5463013]i just did a full 4" exhaust on mine.
Magnaflow 4" system part number 17035 cost 150 shipped on ebay
https://www.ebay.com/itm/Magnaflow-1...72.m2749.l2649
Dang, just went to buy the Magnaflow 4" system that you posted up and it's $500 now! Guess I'm sticking with the 3.5" that comes on the 6.2L. I think it's 3.5" until it hits the resonator and then it's 3" out from the resonator. If I delete the resonator, I'm not sure how I'm going to run 3.5" from the muffler to the tailpipe because I haven't found someone that bends 3.5".
Old Jun 11, 2019 | 06:52 PM
  #38
silentbravo's Avatar
5 Year Member
Guess that seller woke up haha. There are some other kits around $280 still. Dual tip versions were that much I checked earlier today. Although dual 4" out the back is probably a bit tight out the driver's side, through shock and around tire, etc.
Old Jun 14, 2019 | 08:30 PM
  #39
Only got an idle clip. But here y'all go.
Old Aug 8, 2019 | 03:07 PM
  #40
Chrisbequick's Avatar
I just bought that kit off eBay from the link provided for $199.
