What's everyone using for methanol control?
Old Oct 17, 2012 | 12:53 AM
Midnight's Avatar
Default What's everyone using for methanol control?
Just curious on what you guys are using to control your meth. I have the E-Boost street boost controller and it advertises that you can use it to control meth but still need to do some research into it. I would greatly appreciate any input you guys may have. Thanks fellas.
Old Oct 17, 2012 | 04:07 AM
03sierraslt's Avatar
Alky Control kit, it has a controller.
Old Oct 17, 2012 | 06:23 AM
sharpshooter's Avatar
Coolingmist controller
Old Oct 17, 2012 | 02:29 PM
nonnieselman's Avatar
Devils Own Controller
Old Oct 17, 2012 | 02:33 PM
Atomic's Avatar
I have a gauge for that
Alky control
I also have the eboost street, but the alky control has an on setting configurable by boost pressure, so you dont need the eboost to do it.
Old Oct 17, 2012 | 03:30 PM
slowec's Avatar
Alky-control !
Old Oct 17, 2012 | 05:23 PM
JoeyGC5's Avatar
I was using the Snow stage 1 Hobbs switch and a parallel relay to the fuel pump (to prevent false spraying if Hobbs fails when truck is off). I just bought the E-Boost Street controller and will be wiring the methanol pump relay ground wire to the E-boost output to control at 10lbs and over boost. Now the system kicks on around 10-11 via the Hobbs switch.
Old Oct 17, 2012 | 08:00 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Alky control
Old Oct 17, 2012 | 09:04 PM
milkey57's Avatar
What the majority said...Alky.
Old Oct 17, 2012 | 09:15 PM
Wheatley's Avatar
Truck Sponsor
Alkycontrol!!
