What's everyone using for methanol control?
Just curious on what you guys are using to control your meth. I have the E-Boost street boost controller and it advertises that you can use it to control meth but still need to do some research into it. I would greatly appreciate any input you guys may have. Thanks fellas.
I was using the Snow stage 1 Hobbs switch and a parallel relay to the fuel pump (to prevent false spraying if Hobbs fails when truck is off). I just bought the E-Boost Street controller and will be wiring the methanol pump relay ground wire to the E-boost output to control at 10lbs and over boost. Now the system kicks on around 10-11 via the Hobbs switch.
