Whats the best way to build boost off the line?
Old Aug 19, 2006 | 10:59 PM
Blown02Sierra's Avatar
or buy a radix. great boost off the line. but if you dont want to drop 6k, then all i can say is a high stall and two step.
Old Aug 20, 2006 | 12:20 AM
kbracing96's Avatar
Originally Posted by johnrusso1987
I want to try to stay away from torque converters just because this is a daily driver and this thing is also awd so line locks are out, the brakes hold it in place.
Thanks for the input everyone
What the other guys have said, 2500 and under converters a VERY street-able and really not even noticeable on a daily driver. I drive my truck a ton and tow a lot with it and have no issues with the stall, but like the turbo its there when you NEED it.
Old Aug 20, 2006 | 08:53 AM
Steve88's Avatar
Like the others said a good qaulity converter will make all the difference in the world and you will hardly be able to tell its there. I have a PI converter in my Grand National and will be using one in my truck also. My GN cuts 1.44 60's off the foot brake and drives like a sotcker!
Old Aug 20, 2006 | 09:08 AM
8ALTNG's Avatar
Get a 4000 stall and some good hawk pads. I launch at 11#-13# by break boostin it.
Old Aug 20, 2006 | 11:06 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
I have a 2600 torque converter for my daily driver and have no problems. The only differance is when I am at a stop light and take my foot off the brake it won't creep foward.
Some converters are loose and some are tight. Yank's pull under idle, at least the 3 i've had do!
A Yank 2600-3000 converter is great for DD. My setup with SC2800 is so streetable that I almost forget it's not stock while putting around town.
Don't fear the higher stall, it will feel better than stock and get you closer to your power band off the line.
Old Aug 20, 2006 | 11:11 AM
EDawg's Avatar
what kind of stall are you running? how does it feel on the street? please tell me more about your setup! i can't build any boost off the line with out pushing through the brakes. my stall feels way too tight.
Old Aug 20, 2006 | 12:03 PM
8ALTNG's Avatar
I have a 4000 stall PI convertor. It si in a built 4L80e trans. The engine is a forged 4.8 liter with a 67mm STS turbo kit. I put some Hawk pads from Tbyrne on the back and they hold perfect. I also dump a lot of fuel into the engine under load, which helps the turbo to spool faster.
Old Aug 22, 2006 | 11:40 PM
TURBO8's Avatar
Do a two step, synergy motorsports makes a kit. One for N.O.S (has window switch built in) and one for everything else. They are a sponser for ls1.tech
Old Aug 23, 2006 | 08:25 PM
Danville Performance's Avatar
We ran a yank 2600 in our silverado with the LS6 w/magnacharger and we launched at 8psi and it was a beast! I am going to put the convertor in my 03 tahoe best of it's stock driving quality. I HIGHLY recommend the Yank convertors.
Old Aug 23, 2006 | 11:28 PM
TURBO8's Avatar
Very nice, I am getting 5 now but I can build more. I think I will, good info.
