What Turbo Do I Have Exactly??
Old 02-17-2009, 11:00 PM
Ender06's Avatar
Default What Turbo Do I Have Exactly??
I was told it was a pts76. So is this a Precision Turbo. Is it any count. I'll post some pics tommorow.
Old 02-18-2009, 09:42 AM
I AM A MOTHERF*CKER
TurboBerserker's Avatar
How to ID Precision Turbos
Rotating assembly and compressor cover ID
Located on the compressor cover discharge, typically where the hose slips on, on the bottom of the discharge will be either a 4 digit and 1 letter code or the physical name of the turbo, engraved onto the cover.
Example 1: "5031E"
50 is the compressor wheel in MM
31 is the turbine wheel in MM
E is the TO4E compressor cover
Example 2: "GT35RLS"
GT35RLS is a GT35R turbo with a TO4S compressor cover
Example 3: "PT106G"
PT106 turbo with a G trim turbine wheel
Turbine Housing ID
Usually on the side of the foot of the turbine housing there will be a CNC code cut into the housing. May also be found on the face of the discharge side.
Example 1 "THF3-52"
T3 Ford style 5-bolt discharge with a .63 A/R ratio for T350 76 trim turbine wheel
Example 2 "THM3-52W"
Mitsubishi style turbine housing with a .63 A/R ratio for the T350 76 trim turbine wheel with integral wastegate and no divider wall
Example 3 "TH6876A"
T4 style turbine housing with a .68 A/R ratio cut for the 76 P-trim turbine wheel with a 3 5/8" OD V-band discharge flange
Old 02-18-2009, 10:33 PM
Ender06's Avatar
Alright Thanks. Are Precision Turbos any count?? Don't hear much about them on hear.
Old 02-18-2009, 10:38 PM
no title here
skyhighsami's Avatar
Precision makes a damn good turbo
Old 02-18-2009, 10:46 PM
vanillagorilla's Avatar
Most of the time.
Old 02-18-2009, 10:53 PM
no title here
I have had a one and several friends that have them and a friend that is a dealer and he had never had any problems
Old 02-18-2009, 11:09 PM
I AM A MOTHERF*CKER
Yeah PTs are nice turbos. I think that's what Parish ran a lot of the time.
Old 02-18-2009, 11:39 PM
Ender06's Avatar
All i have found so far is:
TDM 76 4S
M24
EC-1
A/R.70
kha4079
10-29-2018 04:38 PM
lxcoupe
09-06-2017 08:24 AM
jtphelps289
09-11-2015 06:37 PM
slowswb
09-05-2015 02:27 PM
06murder
09-04-2015 03:54 PM
Quick Reply: What Turbo Do I Have Exactly??
