What Turbo Do I Have Exactly??
I was told it was a pts76. So is this a Precision Turbo. Is it any count. I'll post some pics tommorow.
How to ID Precision Turbos
Rotating assembly and compressor cover ID Located on the compressor cover discharge, typically where the hose slips on, on the bottom of the discharge will be either a 4 digit and 1 letter code or the physical name of the turbo, engraved onto the cover. Example 1: "5031E" 50 is the compressor wheel in MM 31 is the turbine wheel in MM E is the TO4E compressor cover Example 2: "GT35RLS" GT35RLS is a GT35R turbo with a TO4S compressor cover Example 3: "PT106G" PT106 turbo with a G trim turbine wheel Turbine Housing ID Usually on the side of the foot of the turbine housing there will be a CNC code cut into the housing. May also be found on the face of the discharge side. Example 1 "THF3-52" T3 Ford style 5-bolt discharge with a .63 A/R ratio for T350 76 trim turbine wheel Example 2 "THM3-52W" Mitsubishi style turbine housing with a .63 A/R ratio for the T350 76 trim turbine wheel with integral wastegate and no divider wall Example 3 "TH6876A" T4 style turbine housing with a .68 A/R ratio cut for the 76 P-trim turbine wheel with a 3 5/8" OD V-band discharge flange |
Alright Thanks. Are Precision Turbos any count?? Don't hear much about them on hear.
Precision makes a damn good turbo
Originally Posted by skyhighsami
(Post 4133966)
I have had a one and several friends that have them and a friend that is a dealer and he had never had any problems
Yeah PTs are nice turbos. I think that's what Parish ran a lot of the time.
All i have found so far is:
TDM 76 4S M24 EC-1 A/R.70 |
