what turbo?
#71
Motor upgrades for boost: LS9 head gaskets, arp rod bolts(above 12lbs), gap piston rings(above15lbs), trunion upgrade, LS2 timing chain and gears. Oh and proper spark plugs.
Rearend:trutrac
Trans:freshen up the trans, add a shift kit and let her rip.
Fuel: Walbro 400/450, and biggest injectors you can afford.
Other suggestions for the build.
1) shorter tires, crank the keys down, and remove the rear blocks.
2) get to a track get some baseline times to compare the boost results to.
3) a change of pants for the first time you go wot.
4)Also you need to get a boost gauge in there too.
5) get a real exhaust with a good muffler.
Rearend:trutrac
#72
you think i should pull the gaskets again? i can keep it around 10psi if need be. plan on doing the truion upgrade, need to get a chain, and what gears should i run? what spark plugs? im running ngk's right now. rearend is a deff maybe down the road. tranny will get rebuilt later on" pro low boost till then" and im still looking around for fuel and new valve springs.
1- i may do that if not im looking at 33"S on 18's
2-one day.... lol prob not a option cuz of the new job
3-all the cool kids poop there pants so eff it!
4-im prob going to get a new dm-6 and see with i can do for boost, fuel, and oil pressure?
5-im planning on a magnaflow d-max muffler.
lxcoupe
09-06-2017 08:24 AM
jtphelps289
09-11-2015 06:37 PM
06murder
09-04-2015 03:54 PM
