Pulley swap
Old Apr 6, 2013 | 04:28 AM
Cakes's Avatar
Default Pulley swap
With my current setup (in sig) both Justin from Blackbear and myself feel the truck is maxed out on power. I am running a 2.9" pulley and getting 7 psi of boost at WOT. I, like any performance nut, want more. Is a 2.7" pulley the next logical step? If so, what would I gain in boost? How about power and torque?
Old Apr 6, 2013 | 05:49 AM
TIM Z's Avatar
11 sec. Truck Mod
I would do an 8 rib setup with an OD balancer and smaller blower pulley.
You gain about a pound of boost for each tenth of a pulley size you drop roughly is rule of thumb.And roughly 10hp give or take per pound .
Going with an OD crank balancer you should gain 2 or so lbs of boost .
So I would start with that , the OD balancer .it will help with belt slip , but going to a 2.7 or 2.6 you will see belt slip on a 6rib drive setup.
I did run a 2.6 6rib and an OD balancer so it can be done but like I said I had belt slip.
Boost is wayyyy more fun at 10psi + , I def think you have power left on the table , just make sure you get a great tune and fuel system to support the extra boost.
Old Apr 6, 2013 | 06:27 AM
Cakes's Avatar
Do you think I still would have belt slippage with my added idler below the snout pulley?
Old Apr 6, 2013 | 10:01 AM
TIM Z's Avatar
11 sec. Truck Mod
Only one way to find out bud ! Try it ! I'm sure it will run good with a retune and small pulley , but up top I bet you'll still get slip , maybe not as much as without your idler but prob still some , Leftcoast32 knows all about this subject.
I def first would do the larger OD balancer , that will get ya close to 10psi and will help with belt slip IMO.
But yeah it's def recommended to switch to 8 rib when you pulley down that small
Edit: I have a 2.6 6 rib pulley from south Florida pulley if ya want it 60$ plus the ride . I think I paid 120$ for it , the reason I'm posting is its just hanging on my wall lol
Old Apr 8, 2013 | 12:11 PM
Vortec350ss's Avatar
How is your cam with boost? Mine is very similar!
I'd follow Tim's lead on this one... he seems to be doing pretty well with his truck. I want to do an 8 rib as well...
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
XL7
May 5, 2022 01:48 PM
bigsapper
Jul 28, 2015 12:56 AM
blownss27
Jul 20, 2015 08:59 AM
lo4x4
Jul 5, 2015 05:58 AM
