Which and what size turbo?
Old May 1, 2012 | 02:28 PM
  #21
turbo11z71's Avatar
So to run the Q-trim I will have to change my down pipe correct? Anything else? Or would I be better of selling the mp70 and going with a mp76, which I assume is a direct replacement with no modifications necessary. The PTE 76 gts/.96 is a little too expensive for me at this time.
Old May 1, 2012 | 04:52 PM
  #22
black00chev's Avatar
Slowest turbo build ever!
The 76mm with the p-trim turbine I do believe is the same turbine on your 70 now and should bolt up just fine.
Old May 2, 2012 | 03:05 AM
  #23
foose04's Avatar
You can do the Magnum 76/Q/T4 .96 and it will be a direct swap, not sure if it will laggy enough for you but it's a move in right direction.
Stainless Works
13
Nov 5, 2015 03:31 PM
BlackGMC
Aug 17, 2015 07:07 PM
maxspeed05V
Aug 12, 2015 06:29 PM
FlowmasterMufflers
Jul 30, 2015 05:03 PM
jrplz
Jul 9, 2015 12:07 AM
