what size pulley for the radix?
Old Nov 17, 2006 | 10:59 AM
Default what size pulley for the radix?
i also need to know what size pulley i'll need for the radix to make 10psi. i have a 224/228 586/576 114lsa cam, mild p&p on my heads and long tube headers. i was thinking about a 2.9. is this close or is it definately gonna be smaller. thanks
Old Nov 17, 2006 | 11:18 AM
dewmanshu's Avatar
Moderately Differentiated
5.3L?
a 3.0" on a 5.3 got me 9psi with 2.02intake & 1.67exhaust valves, along with a pretty big exhaust. I'd say 2.9 will do you fine.
Old Nov 17, 2006 | 11:41 AM
Originally Posted by dewmanshu
5.3L?
what cam were you running? and would the bigger valves make you lose boost?
Old Nov 17, 2006 | 12:22 PM
dewmanshu's Avatar
i was running about the same cam, it was a 222/224 if I remeber right. I think...maybe it was a 224/226, I forgot. Your's is a little larger duration, you may loose some boost, but it's not lost power.
Larger intake valve would make more boost, but larger exhaust makes less. More flow in would equal more boost. But in the FI world, getting the exhaust out fast is very important as well. So i only stated those facts to give you an idea of what was going in my setup...my intake/exhaust IMO was allowing a more flowing setup up. So 10psi for you is doable...close, but doable.
Old Nov 17, 2006 | 01:05 PM
where's the best place to buy these pulleys?
Old Nov 17, 2006 | 01:38 PM
moregrip's Avatar
what a rush!
Magnacharger sells them
Old Nov 17, 2006 | 02:04 PM
bud8fan's Avatar
nelson performance has them also...
Old Nov 17, 2006 | 02:35 PM
well magnacharger said that i could get them cheaper thru a dealer so thats what im trying to do.
and nelson performance only has 3.25" and will not be carrying anymore.
moregrip's Avatar
what a rush!
JPA then
