What plugs/gap
For you guys running forced induction, what plugs and gap are you using? Any chance on blowing out the spark with 7lbs of boost? Just trying to weed out a slight stutter I have, because everything else looks good now. I am running what STS recommended but anything is possible. Thanks in advance!
TR6's at .035", but I am going to re-gap to .024", which is a big difference, but it will hopefully tell me if I have found the problem. Any hotter coil packs available? There is a trick to jumping voltage from the alternater, an old GN trick, but I don't want to get that drastic. Thanks for the replys!
Originally Posted by doofus
TR6's at .032", but I am going to re-gap to .024", which is a big difference, but it will hopefully tell me if I have found the problem. Any hotter coil packs available? There is a trick to jumping voltage from the alternater, an old GN trick, but I don't want to get that drastic. Thanks for the replys!
Originally Posted by parish8
same as the other guys. tr6's at whatever they are out of the box.
Originally Posted by FMOS Racing
Geezus, you run a heat range 6 plug at your power level? That's amazing... I run 7s on my small block and 9s in my big block.
