What is it.. found this in my intercooler
Old May 16, 2015 | 06:02 PM
Default What is it.. found this in my intercooler
after the catch can install I decided to clean my piping and intercooler..i found this in the inlet....looks like tar but not sticky , smalls like gas and is rubbery....any ideas
this is the inlet side
this is some of the new piping I am going to put on
including dual nozzle upgrade and dual iat's
Size:  92.8 KBName:  DSCN0136.jpg
Old May 16, 2015 | 06:07 PM
03sierraslt's Avatar
Old dried up oil is my guess.
Old May 16, 2015 | 06:10 PM
TrickTurbo's Avatar
Truck Sponsor
Look inside all silicones.
Check turbo inlet as well.
You can bet some of the pieces if small enough, are inside the core.
Old May 16, 2015 | 06:27 PM
there is nothing, but oil on inside the exit on the intercooler, but could be blocking tubes...going to rinse with simple green and alcohol
Old May 17, 2015 | 12:17 PM
Vortec350ss's Avatar
Wow... thats weird looking.
How did you have your breather hoses set up? Oil would have to be my guess too.
Old May 17, 2015 | 12:54 PM
JordanH's Avatar
Restricted
That's crazy looking.... Was your intercooler and piping shipped in styrofoam peanuts? If so you may have not gotten them all out, and they turned into black crud?!
Old May 17, 2015 | 02:29 PM
did a cleanout today with a gallon of seafoam and heet to finish rinse...5 rinses to get it to run clean...a lot crap came out
Old May 17, 2015 | 06:13 PM
Gadgetized's Avatar
We're you injecting something like alcohol pre intercooler? Maybe the tubing was being broken down by the fluid.
Old May 17, 2015 | 08:08 PM
GMCtrk's Avatar
Check turbo seals
Old May 17, 2015 | 08:26 PM
the seals on the s/c are fine, it has the correct level of oil in it...my original evap was sucking right from the two valve covers out of mopar style breathers, threw -12 line right to the inlet of the supercharger , I thought the breathers would separate the oil from the vapor. it only did in low rpm's... at 6k the blow off valve would have a mist of oil that came out of it, so I socked it, to keep the oil off the belt. not injecting anything pre intercooler...
