View Poll Results: How would you like your boost?
Kenne Bell 3.6LC
3.33%
Whipple 4.0
13.33%
Procharger F1R
13
21.67%
Precision 88mm Turbo
37
61.67%
Voters: 60. You may not vote on this poll
What do you think?
Old Feb 22, 2011 | 07:15 PM
smokeshow's Avatar
Mod with training wheels
I thought about posting up a smartass comment, but I figured I'd stick to the books on this one lol.
Seeing as you are more of a low-stall converter fan, I'd say go with a PD blower. However in that case 2wd is not gonna be helping you, street or track.
Old Feb 22, 2011 | 07:21 PM
Atomic's Avatar
I have a gauge for that
Thats a first for you Jake
I havent bought anything yet, so I still can change my mind...
Old Feb 22, 2011 | 07:34 PM
badblackhemi's Avatar
Originally Posted by Atomic
Mostly a street toy with track action....goal is a solid 800hp to the ground.
Well then, IF it was my truck, I think 4wd with the KB would be FUN and have all the power you want right off idle! But, it's all up to you man, it's your truck
Old Feb 22, 2011 | 07:53 PM
Swerve7rpm2000's Avatar
Id like to see you stick with the PT88
Old Feb 22, 2011 | 08:03 PM
Atomic's Avatar
Originally Posted by BlackGMC
Why no tvs2300?
Not big enough and too common
Old Feb 22, 2011 | 08:04 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
With proper suspension attention an awd setup can hook great even with a lot of power. Look at what Parish was able to do with 1000rwhp. There are a few other guys tickling higher HP ranges that do just fine with a lot of power. No way I would build a high HP truck without it powering all 4 wheels. Look at all the high HP 2wd guys, they all wish they had 4wd.
Old Feb 22, 2011 | 08:10 PM
Mangled03gmc's Avatar
Baltimore Whore
PC
Old Feb 22, 2011 | 08:31 PM
sharpshooter's Avatar
besides just a peak hp goal
also how do you want the power curve to look?
or I can say it like this- how do you want the power delivery to come in as you drive?
Prochargers boost increases with rpm.
Old Feb 22, 2011 | 09:14 PM
2004SSS's Avatar
id pretty much copy parish's truck and keep the 88 kit you have , cheapest route and youll make more power than most of those . use the 4wd t case as well , they can hold power lock all wheels at 50/50 and do a burnout to at least heat the rear tires.
you can run 9's in a 4wd man its been done.
Old Feb 22, 2011 | 09:20 PM
Atomic's Avatar
Im not really shooting for a time goal, just something rediculous and fun to drive...
...to be honest, I didnt really like how the power cam on with the turbo. Maybe it was because my truck was so heavy, or the cam wasnt a good match or what, but it just wasnt as fun as the blower setup I had before that made considerably less power.
Since this isnt a DD so I could see myself using a larger stall (3400ish I guess), and a bigger cam.
