what do you guys think
Old Aug 16, 2010 | 05:49 AM
slowlsx's Avatar
Default what do you guys think
well im selling my kb s475 kit and im putting my truck back to stockish. i have the following parts:
342's
243's
3200 circle d (dual disk)
small turbo cam
caltracs
bogarts
if i go with KB ill put long tubes
now i want to either go with a 2.2l kenne bell with 10psi or a trickperformance level 1 kit at 8-10 psi. i will have my 100 shot also when needed
what do you guys think this mild set up will run?
does 12.0-12.30 sound doable boost only
Old Aug 16, 2010 | 05:53 AM
Quik's Avatar
5 year bitches!
why do you want to use another turbo sellers product when you already have a turbo setup? if youre going back to stock then make it stock. use what you have, its already paid for
Old Aug 16, 2010 | 06:57 AM
slowlsx's Avatar
kit is to big,i can sell this and it will pay for a small kit and ill have money left over to finish my other build, it will build boost fast with a small t70 or supercharger and be a good DD. i didnt ask for criticism on why im doing what im doing, i just asked for opinions on the times it would run
Old Aug 16, 2010 | 07:22 AM
Quik's Avatar
5 year bitches!
ok why not just put a 70mm on the kit and be doen with it?
10 psi on a good setup should be in the 500 range. a good running rcsb with 500 should be in 11s easily
Old Aug 16, 2010 | 09:45 AM
sureshot's Avatar
That's what I was thinking. If you're running a 370 in a rcsb, and you want to boost it to 10psi, you should have no problem meeting your goals.
Old Aug 16, 2010 | 10:58 AM
smokeshow's Avatar
Mod with training wheels
How much boost did you end up making with that s475? I remember you said you brake stalled it to 2psi, but you weren't really pushing it.
Old Aug 16, 2010 | 11:16 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
S475 is a t6, a t70 is a t4...
Old Aug 16, 2010 | 12:28 PM
slowlsx's Avatar
the truck never got completed, i never ran it,never made any hits on the street. after kit was installed i put it to the side then i got my vette so now im just selling it and putting something small on the truck that will boost pretty quick for the streets and be capable of atleast low 12's on the street. i just didnt know if my 342's and 3200 stall would get me there with a kenne bell.
Old Aug 16, 2010 | 12:30 PM
slowlsx's Avatar
let me also ad that this is not a 370... i had put that in my sig when i was building a 370 but then we put it in my dads camaro. this is just a plain old 5.3 with 243s. sorry for the confusion need to update that
Old Aug 16, 2010 | 01:27 PM
NightmareTBSS's Avatar
So you want a stock 5.3 to run 12.0s with a kenne Bell?
