What can a turbo converter foot brake to?
Trying to figure out if my converter is set up too tight. Feels good and tight up top, but way tight down low. Wondering what everyones setup footbrakes to. Mine literally feels like stock.
Punch off idle spins tires at 2000
Regular footbrake spins tires at 2000
Syty shuffle and ebrake spins tires at 2200
Syty shuffle/ebrake/and pulling 10 degrees of timing spins tires 2500rpms @6psi
Syty shuffle/ locking trans in 2nd gear spins tires at 2900-3000 @8psi
Maybe a hydroboost or 2 step would be a better idea then loosening my converter.
2200 and syty foot brake to 2800. Changed to a 9 1/2 3k and it would flash to 28-3000. Syty foot brake to 4400 if I held it for a few seconds.
Thanks! This is the info I was looking for. Lane said this should be close to a 3k. Its a 10" too. I tried locking the trans in 2nd, and I could climb up to 2800-2900 before it spun tires. This was without the timing retard, at 8-10psi.
You want power getting to the ground...the fact that it spins the tires at such a low rpm means its getting there. If you are spinning at 2000, why do you want to launch at 3000? Converters with FI are not the same as NA converters. With a turbo you want it as tight as you can get it and let the turbo do the work.
