What AFR when spraying meth?
Old Jan 21, 2013 | 11:26 PM
2ktransam's Avatar
If you keep a little water in the mix you can lean it out a little with out an issue. I run my truck at about 11.5 A/F with meth normally but I have leaned it out on the dyno before just to test it and it is a huge difference in power. From 10.9 to 12.0 A/F was about 40rwhp on my truck at 13psi. I also have my timing set to start pull timing at 100 degree IAT in case something happens to the meth setup. I had an injector clog up on me at the track running 17psi and it didn't hurt the engine since it was pulling 8 degrees of timing.
Old Jan 22, 2013 | 11:58 AM
charcold-bowtie's Avatar
I retuned back to 11.5 on mine.
Old Jan 22, 2013 | 12:26 PM
nonnieselman's Avatar
Originally Posted by BlackGMC
Cool seems like 11.2 is a good AFR to shoot towards.
BTW i am running 2 nozzles. One being a 3 and the other a 7. According to a calculator on Devils Own website, it recommended a 9 for a 6.0, 8psi and 6000rpm shift point. So i will be spraying a little more than recommended.
Im running a DO10, DO14, and a D07 nozzle..
it will suck 3 gallons down fast if im not careful!
Comes on 10% at 4-5psi and 100% at 15psi, straight M1? or M2 methanol. i cant rem, we have a 55gal drum of it.
My target AFR is 11.2 from 4000+rpm
Old Jan 22, 2013 | 02:33 PM
black4.8's Avatar
thats a lot of meth. i think you might have a problem. ever thought of getting help. my DO 7 and 10 together will go thru it fast, can't imagine a 14 on top of that.
Old Jan 22, 2013 | 02:47 PM
I had it setup to start spraying at 2psi and 10% and it would suck it down some kinda fast towing.
retuned it so it will only spray at the highest boost with my cutout closed. Last a whole lot longer!!!
Stock48 is spraying equiv to 3 DO14 nozzles.
twake_410
Apr 14, 2016 09:58 PM
Mr. Chainsaw
Oct 18, 2015 08:00 PM
turbo6c3
Oct 5, 2015 06:11 PM
JordanH
Oct 3, 2015 03:59 PM
old motorhead
Sep 29, 2015 08:22 PM
