What about a self contained oil system for a remote turbo?
Thinking of building a one gallon tank, with a filter, and cooler on the side, with a pump. So I wouldn't have to run oil lines from the engine to the turbo and back. What do you guys think?
Thanks.
Thanks.
How do I change this text
I've thought about that more than once, ifact I think some-one else has posted about this before. It would be cool but the bottom line is YOu would still have a extra oil pump to fail, and it would be heavier. It would be cool to beable to cycle oil threw the turbo to help cool it though.....
I think that a self contained oiling system would be much more complicated than running oil lines to the turbo. It is not that hard to run them- I just put a T on my oil pressure sending unit, then a 1/4 NPT to -4 AN adapter, then a -4 Nitrous hose to the turbo. Then out of the turbo into my pump, and a line to my valve cover. Here is a pic of my adapter...
T setup from Lowes- $5
all AN fittings- $10
Funtion 7 turbo oil restrictor flange and drain flange- $25 ebay
15' oil return hose from Advance Auto- $15
fittings for return hose from Lowes- $3
Then your choice of oil return pump.
