What % meth is in 0* washer fluid?
Old Jan 14, 2013 | 04:22 PM
BlackGMC's Avatar
Resident Retard
Default What % meth is in 0* washer fluid?
Just curious to what % meth is -0* washer fluid?
Old Jan 14, 2013 | 04:38 PM
nonnieselman's Avatar
ill post the chart.. but i think its 8-12%?
Old Jan 14, 2013 | 04:41 PM
dunnu know what i did with the chart.. but look on page 24 of this PDF..
i was a lil off.. 0* is ~23%
http://www.peakauto.com/pdf/msds-pea...hield_wash.pdf
Old Jan 14, 2013 | 04:42 PM
+20 F Washer Fluid - Contains approximately 7% methanol.
0 F Washer Fluid - Contains approximately 23% methanol.
-10 F Washer Fluid - Contains approximately 28% methanol.
-20 F Washer Fluid - Contains approximately 35% methanol.
-25 F Washer Fluid - Contains approximately 38% methanol.
-50 F Washer Fluid - Contains approximately 62% methanol.
Old Jan 14, 2013 | 04:44 PM
BlackGMC's Avatar
Resident Retard
Awesome thanks... So the methanol helps with octane, what does the water do help with IAT or EGTs?
Old Jan 14, 2013 | 04:48 PM
water drops IATs better than Straight Methanol.. and Water is said to have an infinite octane..
Water does help with EGTs also.
Old Jan 14, 2013 | 04:49 PM
never seen this either.....
Razathorn's Alcohol Injection Calculator
Old Jan 14, 2013 | 05:09 PM
oakley6575's Avatar
Where do you find -50 wwf?
A lot of guys on here just run strait meth.
Old Jan 14, 2013 | 05:23 PM
03sierraslt's Avatar
If I recall it has to be more then 50% meth to be flamable.
Old Jan 14, 2013 | 06:39 PM
TrickTurbo's Avatar
Truck Sponsor
U can always add/mix HEET if you can't find -0 washer fluid.
I recommend finding a product and buy several gallons.
The summer mixes will have less meth and won't be available for the -0 zero stuff.
At least around here its that way.
