Well wel just returned from a ride with the boost gauge hooked up
Old Aug 18, 2008 | 09:52 PM
Mangled03gmc's Avatar
Baltimore Whore
Smile Well wel just returned from a ride with the boost gauge hooked up
Now for a few ??? Where should my happy spot be as far as vac goes? or what are you guys seeing? Also as I suspected it is boosting 6lbs. So the 112lsa cam is def bleeding boost.. What would be the next pulley to get me in the 8-10 area? It is 3.40 on there now, other then that everything is working correct. Thanks for the help on some of my ??? guys, thats why I love this site. Now to get the tune spot on
John
Old Aug 18, 2008 | 10:51 PM
Baltimore Whore
Anybody (crickets in the backround)
John
Old Aug 18, 2008 | 11:02 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
happy spot? What does it read for vacume now? I read 19 inches at idle/in gear. 15-10 inches cruising. Is that what ya mean?
Old Aug 18, 2008 | 11:05 PM
Baltimore Whore
Yesir, I am really close to them numbers.. I take it if I had a vac leak the numbers would be affected by that correct?
Old Aug 18, 2008 | 11:07 PM
trever1t's Avatar
I'd think so. I seem to watch it but really don't know if it is a good monitor of engine health.
Old Aug 18, 2008 | 11:14 PM
Baltimore Whore
Hmm thats the thing, everything else looks really good, including the vac numbers, comparing them to yours. Justin seems to think it might have a leak. I have checked everything other then the manifold gasket. It never leaked before, was in perfect shape, I can't find anything, fig if the vac numbers were off compared to others I would be able to use it to be sure if it had a leak, I dunno I am going to have and shoot him down a few more logs. This mystery has me stumped.. Damn truck
John
Old Aug 19, 2008 | 12:44 AM
StrokerAce03's Avatar
John
Just as I read that I heard some crickets start chirping outside my window.
What're your cam specs?
Old Aug 19, 2008 | 04:47 AM
Baltimore Whore
224 581 224 581 112lsa
John
Old Aug 19, 2008 | 05:05 AM
03sierraslt's Avatar
John
With that cam you are not going to be pulling as much vaccum as Bill, I dont know exactly what it should be but I would guess around 14-13" at idle. Maybe I am way off.
Old Aug 19, 2008 | 08:31 AM
NegraRCSB2X4auto's Avatar
my vac reads like bill's 20 at start up and around 15 or cruising. I've got 3.8 pulley on the 5.3 and only reads about 8psi. I either have a bad signal or bleeding boost from somewhere. I've only had a gauge on there a month so I'm not sure what I had when I first installed the kit. I've got a 3.6 and (3.4 or 3.2) I could slap on if I felt the need
