Water/Meth injection systems...
Old Jun 6, 2006 | 03:12 PM
Superado's Avatar
11 Second Truck Club
Default Water/Meth injection systems...
This is the system that I have installed...
http://www.aquamist.co.uk/dc/dc.html
There are several different systems used by you guys.
Please reply with your comments in regards to this unit vs others.
As always...Thanks
Attached Thumbnails Water/Meth injection systems...-sys1s1.jpg
Old Jun 7, 2006 | 07:42 AM
dewmanshu's Avatar
Moderately Differentiated
so...this system is designed for water only? I don't see ratings on the pump. You know fuel ratings as so the pump can handle the meth...if that's your choice. Looks okay if water only is your thing.
Old Jun 7, 2006 | 07:49 AM
Superado's Avatar
It was originally designed for water injection only.
The common mix is 50/50 preferably distilled water and methanol
Alot of guys use distilled water and isopropyl alcohol.
Heet is a good source of meth if you can't find it, I believe that it is 98% meth.
It seems that everyone here uses injection for more than it's intended purpose of controlling detonation. I am by no means well versed in either. The system was recommended when I had it installed in Miami, due to the possibilities of detonation due to extreme temperatures.
Old Jun 7, 2006 | 03:53 PM
Superado's Avatar
BTW, here is a good link to meth sources that I found on AquaMist's website today...
http://www.turbobuick.com/forums/sho...d.php?t=121500
D1SCSS
Jul 25, 2024 06:54 PM
turbo6c3
Oct 5, 2015 06:11 PM
Wrecker 426
Sep 29, 2015 11:00 PM
Justin87gn
Sep 10, 2015 12:06 PM
cosb
Aug 24, 2015 09:08 PM
