Water Injection Kits aka meth kit
witch kit should i go with water injection kit should go with from Devil.
Here are the links.
http://www.alcohol-injection.com/wat...stage-1-8.html
http://www.alcohol-injection.com/wat...tage-2-49.html
Here are the links.
I've been running there progressive kit on my truck for over 3 years now. Only problem I had was after 2 years, I had the pump die. They sold me there latest pump with much better components for there cost on it and I've never have a problem with it since. I've probable put 40-50 gallons of WWF and a few gallons strait meth though it.
Haha, no... Didn't you have a pump die?
Chance, the guy who owns D.O. has a 455 Olds or Buick turboed, that he has done a TON of experimenting with everything under the sun from strait meth, ethanol, xylene, every kinda mix you can imagine, he found about a 50/50 mix of meth/water was best he could come up with for cooling and detonation suppression, but everyone has their own option...
High on diesel fumes
hate to jack this thread. but when tuning with meth can you tune ***** out on 93 and then spray the meth on it, :it will be rich then: then just keep adding timing and boost till it leans back out? i just did not know it that is how everbody is doing it..
